Windows Desktop Customization Tools with Updated Icons
Hi All,
I have very basic knowledge about my computer. I have a query and want someone to help me out. I want my system to look colorful. I want to have all kinds of icons on my desktop. I installed Mozilla and want it to get on the quick launch button on the desktop.
Please someone help me and tell how to enable all these features on my system so that it looks colorful and updated with many icons.
Thanks in advance!
Best Answer by Fraank Waster
Answered By 5 points N/A #133586
Hi Jeffrey,
It seems that you want to customize your desktop. I have that craving too. It represents our personality. It's fun and exciting. Let me help you out. There's a software that has a feature of changing desktop themes and icons. I use Tune-up Utilities. Tune-up Utilities also helps your PC to increase its performance.
Download Tune-up Utilities and install it. To change desktop themes and icons, you need to download Visual Styles for themes and Icon Packages for icons. Get Tune-up Visual Styles and Icon Packages Here.
Heres how to customize your PC:
1. Open Tune-up Utilities. Select customize. This will open tune-up styler.
2. At the bottom, click visual style.
3. Click add then browse the visual style that you download.
4. After selecting your theme, click apply.
For desktop icons:
2. Select system elements.
3. Click icon packages, browse the icon packages that you download.
4. After selecting your icon package, click apply.
To add Mozilla Firefox on the quick launch toolbar. Just drag it to the quick lunch toolbar. If you cannot see the quick launch toolbar, right click on an empty space of the taskbar select toolbars then select quick launch.
That's it. Enjoy!
Answered By points N/A #133587
Jeffrey A Parker, to make your system colorful you can change Theme, Wallpaper, by changing the Icons, changing your Windows colors etc. as well using softwares.
In my knowledge, Windows Blind is the best for this purpose. It is a nice software which will make you able to change the entire look of your Windows. Though you will use Windows XP or Vista, 7 or 8, you will have the best eye-catching themes through this program.
Download it from here. With this software, you will also be able to create your own customized Windows Theme. For this purpose, you need to buy an additional software called “Skin Studio”. But there are many designs found on their website which you can use on your own desktop.
In order to customize your Firefox, first of all, it is best to use the latest version. Get it from here. Then, go to the extensions' collection. There, you will be able to find out thousands of add-ons and themes to customize your Firefox.
