Windows Error Code 1000 Solutions
Facing regular errors with Photoshop CC and a few other applications that results into crashing of the application. There is an error code 1000. I set up a task to get notifications of each error 1000. This told me when these applications crash. They usually go down in the “save as” dialog. What do I need to do to fix this?
Answered By 0 points N/A #292224
You can clean start the operating system to determine the interference of other applications. Visit this link for that
https://support.microsoft.com/en-us/help/929135/how-to-perform-a-clean-boot-in-windows
You can then scan for any virus using the below link
https://docs.microsoft.com/en-us/windows/security/threat-protection/intelligence/safety-scanner-download
You can reinstall Photoshop, that may work or contact Adobe support.
