Windows Error: Is026 Brother Driver Suite For PC
I have to install the brother driver suite for my PC. What are the step to do so? I keep getting the error is026 brother during installation.
Make sure you have downloaded the right version of brother driver suite for PC. Please check the system requirements of the software. Always download such software from trusted sources or official websites. Once you are sure you have the correct setup file, make sure you execute the right one (Setup.exe) on your PC. Locate this file on your PC and make sure the software version is not corrupt.
If you are installing the driver for your Brother printer, make sure that printer software is compatible with your operating system. The software or driver that makes the printer work and recognizable on your operating system requires a supported platform. Printer software are not universal or work on all operating systems. They have target operating systems where they can be installed and used.
To check the specifications of your printer, go to Brother Support Center. Here, enter your printer’s model number to find its driver. Once you find your printer, check the driver’s compatibility and verify that it supports your operating system. Also, when installing the driver on your computer, make sure the printer is connected to your computer during the installation.
