cperez
Posted on - 03/15/2012
Hi there,
I want to install Logos 4, but I consistently receive the error in the picture below. I've tried reinstalling Windows Home, and I’m still getting Visual C++ messages and in some cases this errors saying that the registry is corrupt.
I have viewed the similar problems as this on the web, but I am not having any lucking figuring out what the problem is. My current setup is Windows 7 Pro 32bit on an Intel Core Duo 2.8GHz – 4GB RAM
Cheers for the help!
Logos 4 Prerequisites
An error occurred during the installation of assembly
'Microsoft.VC90.CRT,version='9.0.30729.5570",publicKeyToken="1fc8b3b9a1e18e3b",
processorArchitecture="x86",type="win32". Please refer to Help and Support for more information. HRESULT: 0x800736FD.
Windows Home and Visual C++ errors when installing Logos 4
As you have posted the problem which is showing that you are not able to install the software logos 4. The picture attached is showing that it is the problem with the software you are installing there are some possibilities due to which this problem is occurring:
1. As you have told that your windows is 32 bit but look like this software is 64 bit therefore it is not going to install on your windows. So for this get the 32 bit version of the software logos 4 and then install it.
2. The software you are using might have file problem and there are some file which are missing in your back up software so bring the new copy of the software with 32 bit version and then install that version.
