Windows home server codec 2011 installing guide
I want to install streaming Windows home server codec 2011 ? But I don't how to install it or where I find it. Anyone can provide me a guide for installing WHS 2011 codec ? help me ….
Dear Wood,
Here is a solution for you; I hope it'll work.
You can transfer or two. 0. That is in two sorts (with & without TV guide), the link is additionally connected to transfer orb.
http://www.orb.com/en/download.html
Installation guide
Install ffshadow or k-lite codec pack and keep default settings.
Install Orb two.0. Once putting it in, you get the “Welcome to Orb” wizard. Press Next twice, and fill in your account data.
Press Next once more, and again. A system check can occur, afterward press Next once more. Now, we have a tendency to see the choice to put together Orb to stream your media. Affirmatively ready hand-picked, thus we have a tendency to press Next. Choose the network kind you bought. Mine is mixed, thus I select each (Some devices on wireless, some on wired) and click on Next. By currently we’ve finished the wizard, thus we’ll click on shut.
Mr. Wood you can install your WHS CODEC by following these links its very simple method to solve your problem just open and download them by given instructions.
1: ffdshow
https://sourceforge.net/projects/ffdshow/
2: K-Lite
http://www.free-codecs.com/codec_packs.htm
3: Orb
Download of Orb is available in two flavours With or without TV program guide choose one of them which you need.
Enjoy Streaming
Notifications
