Windows installation problems for Anti-Malware
Hello!
Before some days I read a blog about malware, spy  and worm protection. Then I get a suggestion for use Malwarebytes software. Because this software has many good  review. So I decided after I download it and install.
But when I click to run option for install it cannot be install properly and says: unable to execute file. Please see this picture:
Give me  a good suggestion about this utility software and installation process.
Best Answer by marsh watson
Answered By 0 points N/A #118002
Guy Mathys,
You are getting this error because the anti-virus program you have may be blocking the installer file and even MS Defender might have quarantined the file. You should disable your anti-virus app and MS Defender before attempting to reinstall the Malwarebytes again.
Click download a fresh version here
Happy Computing,
Answered By 0 points N/A #118005
Hello Guy Mathys,
The main cause of this error message is some sort of Malware running your PC which deletes some files that are required for installation of Malware Bytes (mbam.exe). You have to download randomized renamed mbam.exe version (http://downloads.malwarebytes.org/mbam-download-exe-random.php). Place the renamed file under the Malware bytes folder in Program Files x86 folder. Then run the program it will run without any error. Once it runs, click on the update button.
