Recently I required to purchase a bundle regarding forum 2008 Rural Computer calls that have recently been ordered with a Select As well as correspondence.
My personal difficulty has been I could truthfully not necessarily receive the computerized initial functioning in the “TS Licensing Manager” instrument equally Select Additionally just isn't stated as one of the accessible licenses software along with trying make use of Pick out as well as Start bought our simply nowhere buy:
Error:
Install Windows
Windows could not pause or process the unattend answer file for pass
[specialize]. The settings specified in the answer file cannot be applied. The
error was detected while processing settings for component [Microsoft-
Windows-Shell-Setup].
Windows installer error to pause unwanted answer
Hi Jeff,
Here your problem is easy, its most probably with the computer name, you need to put it with spaces in between names, so here is the solution;
In the computer name type a name with one word such as AMD640280
It should work.
Hello Jeffrey,
I just found out how to fix that issue you are currently experiencing. The solution was to delete a user from the following location in the registry that doesn’t exist anymore on the computer after finishing deleting them from the machine using control panel users app “HKLMSoftwareMicrosoftWindows NTCurrentVersionProfileList”.
Hope this help.
Elliottsims
Hi there user:
This is the case, you are running a Windows Server 2008 R2 installed using Unattend.xml file. The problem occurred because the file was applied while you perform the upgrade.
To get rid of this error, click to Start, and type ‘regedit’ on the Start Search box. Click to view Programs list and then click regedit.exe. Locate and right click this key. HKEY_LOCAL_MACHINESOFTWAREMICROSOFT. Delete this key and then exit.
Problem solved!
Thanks for asking.
