bilu billa
10 points
Posted on - 01/30/2013
Hi experts,
I want to install Windows on my driveless laptop so have to transfer from a CD with Windows ISO to USB nova to boot. Since I have a small USB drive, is it possible to transfer the ISO files after extracting then send to the destination computer in pieces?
Windows iso to USB nova
I'm sorry but that's not possible. For successful installation you need move complete .iso file to USB flash drive. For moving .iso file to USB flash drive you can use UNetbootin: http://unetbootin.github.io
It's simple tool for moving .iso image to USB flash drive. After moving .iso image (keep the USB flash drive in the computer) restart your PC, go to BIOS settings and set USB flash drive as first device. Save settings and restart again, then your USB flash drive should be booted and you can install Windows on normal way, like from CD.
