Windows Live Mail Error Id 0x800ccc0d
I’ve been getting Windows live mail error id 0x800ccc0d while trying to get an email with windows live mail. Can anyone tell me the fix as soon as possible?
The error code you’re receiving can be broken down into two causes:
• Incorrect POP settings
– You can check this with your Provider.
• Windows firewall blocking your port
– Go to your windows firewall to unblock.
Also, you can try re-adding your windows live mail.
You can also try resolving machine configuration in windows live mail if you find any issues.
Also, don’t forget to check the date and time settings of your PC, sometimes even the silliest thing can cause a big problem.
I hope the suggestions might help you.
