Hello experts,
I am using Windows 8 Pro 64 Bits in my Computer, an ASUS F3SC. I have installed NVIDIA Driver and working very well. When I install Windows Essentials 2011 or 2012, Windows Live Movie Maker does not work, giving the message in attachment. I really need your help.
Thanks
Sorry, Movie Maker can’t start. Make sure your computer meets the minimum system requirements before trying to start Movie Maker again, and then try to update the driver for your video card if Movie Maker still doesn’t start.
What are the system requirements for Movie Maker?
Learn More.
Windows Live Movie Maker can’t start
The System Requirements for Windows Live Movie Maker are as follows:
1GB RAM. If you are editing HD videos then 2GB recommended
Processor with 2-4 GHz clock speed or higher
Internet Explorer 7 or later, Firefox 3.0.1 or later
Graphics card supporting Microsoft Direct 9.0c or later and Pixel Shader 2.0 or later
If you are using Internet functionality you need a dial-up or broadband Internet connection. If your system satisfies all requirements mentioned above, I would recommend un-installing video card and re-installing again.
If you install Windows Live Essentials 2011 or 2012 on a computer with 64-bit Microsoft Windows 8, there should be no problem because the operating system is supported. Windows Live Essentials 2011 supports Windows Vista, Windows 7, and Windows 8. It dropped support for Microsoft Windows XP.
Windows Live Essentials 2012 supports Windows 7, Windows 8.x, and Windows 10 including Windows Server 2008 Service Pack 2, Windows Server 2008 R2, and Windows Server 2012. Windows Live Essentials 2012 doesn’t support Windows XP and Windows Vista. Since you have Windows 8, try updating it to Windows 8.1 on the Windows App Store.
Since you have a fully compatible operating system, the problem is probably with the video card you have. If your video card supports Microsoft DirectX 9 only, Windows Live Movie Maker 2012 will not start. The problem is caused by an access violation that occurs in the D3d11.dll file.
To fix the problem, you need to update your operating system or replace your video card with the one that supports Microsoft DirectX 10 or higher.
