Windows live movie maker error
Hi guys!
I am making a video slide show with my windows live movie maker. I made a save file back at home. When I tried to install windows 7 at my friends house. It was fully installed and all that, but when I tried to open the movie maker I got this error message:
MovieMaker.Exe – System Error
The program can't start because WLXPhotoBase.dll is missing from your computer. Try reinstalling the program to fix this problem.
I read something about the requirements and all that, but I'm pretty sure that my friends computer surpasses the requirements. Any ideas on how to deal with this?
Best Answer by James_Smith
Answered By 0 points N/A #82726
If the system is fulfilling all the requirements then that is pretty good. Maybe there is some kind of virus which causing this problem or corrupting the files of your Windows live movie maker. Try to find that and scan your computer with a good and registered Anti-virus. Or you can also fix the problem be restarting your system and ten go to safe mode and try to run your program. if that is also not happening then uninstall it and reinstall it after restarting your system or else there are some corrupt files or some files are missing from the beginning. So try to install your program with some another disc or download it from internet and then install it, that might work.
Answered By 10 points N/A #82725
First Part:
  • Today I am going to tell you, how to fix the problem (Windows live movie maker error). Well, please follow the instruction.
  • At first you need uninstalling windows live movie maker, If you haven't done so, try uninstalling all of the Windows Live components by going to "Control Panel > Programs and Features" and then re-installing them.
  • Second Part:
  • On your screen print we find some dll file was missing from your PC. Well, at first we find the dll file and then we will replace in Movie Maker Folder.
  • Let’s find out the dll file from here:
  • https://www.dllme.com/dll/files/wlxphotobase_dll.html downloads the file and put the dll file to this directory C:Program FilesMovie Maker.
Thank you.
