Windows Live Writer gives an error message
Hello Everyone,
I have started using Windows Live Writer to create blog posts offline but it gives me an error message “the xmlrpc.php error”. I have also checked the xmlrpc button in the writing settings. I have contacted my host if they have blocking access to the file and also I tried to find solution in the internet but still no answer to this.
Then I try to edit the file .htaccess but again it gives me error “500 error message”. Then again I edit the file php.ini. file and disabled all the plug-ins but no response seen. Moreover I also tried using different blogging software like ScribeFire but it gives me the same result. Can someone help me resolve this error? Your help would be highly appreciated.
Thank you in Advance.
