Jimm Hanson
Posted on - 01/14/2012
Is there any problem to use both of the email services?
I am using Windows 7 and installed MS Outlook 2010 and Windows Mail. Is there any problem to use both of the email services? My Windows Live mail is working properly but MS Outlook gives problems. I will be thankful for your help to get out of this problem.
Windows Mail and MS Outlook
Hi Jimm,
Can you enlighten us by providing the error you are getting on your Microsoft Outlook? By right, it should be ok to install and use both Microsoft Outlook 2010 and windows mail. They are two different email applications and can work side by side as long as the settings are properly configured.
You just need to make sure that your Microsoft Outlook is properly configured. To add a new mail on your Outlook, you just go to Start > Control Panel > Mail > Add a new Profile > Choose the server settings for your email and you should be able to open it.
Aristono
