Dan Alba
Posted on - 03/23/2013
Hi All,
I have windows 7 OS and wanted to know if i can watch 3D movies with Media player and if yes then what are the plug in's needed and what else do i need to know?
Does my laptop screen needs to be a 3D compatible one?
Media player in Windows 7 does it support 3D?
Thanks
Dan
Windows media player does it have 3D functionality?
Hi there
In order to play 3D movies you don’t need a 3D Display but the quality of output will be very low. Most of the time it won’t look like a 3D version Because of the Display quality.
And Windows 7 media player almost support all the formats. But If you can download any other player it will be more Suitable to view 3D version of movies. There are 3D players in web.
Hope these answers helped you
Taylor B Campos
Thank You..!!
