Windows Media Player Error A CD recorder wasn’t detected
Meira Flores 20 points N/APosted on - 02/02/2012
Hi friends
I am receiving the message reading “A CD recorder wasn’t detected” while working with Windows burning software to make copy of the files and folders to a CD.
Connect a CD recorder and try copying the files again. More information
If you want to copy files and folders to a CD, the task requires burning the data to an optical disc. For this to happen, you need a CD writer or a DVD writer. With that error, it means you only have a standard optical drive and you cannot use it to burn files. It is not capable of burning data to an optical disc.
LG Blu-ray writer
You need to buy a new CD writer or DVD writer so you can burn your files and folders to a CD or DVD disc. With a CD writer, you can only burn CDs. But with a DVD writer, you can burn both CDs and DVDs. The one in the image is a Blu-ray writer. It can burn CDs, DVDs, and Blu-rays.
1....
