Pedro Mahon
60 points
Posted on - 02/21/2013
I have an error on having installed the WMP…
Windows Media Player
Windows Media Player is not installed properly and must be reinstalled.
Do you want to install the player from the Microsoft web site?
How can I arrange it? Must I install formulaic WMP web site?
The possible reason for this is that the wmp.dll is out of sync with what you are trying to install. Try the following workaround and see if this will help you:
1. Close Windows Media Player, and then click Start> All Programs> Accessories.
2. Look for the Command Prompt option and right-click it. Select Run as Administrator.
3. Hit Continue or give the Admin credentials if needed.
4. Type the command below on the Command Prompt and then press the enter key:
UNREGMP2.EXE /UPDATEWMPVERSION
5. Close the Command Prompt and try to reinstall WMP again.
