I encounter a problem with Windows Media Player where it was not open and that you receive the error message;
D:CaiusMusicTV ShowsFamily GuySeason 23 Da Boom.m..
D:CaiusMusicTV ShowsFamily GuySeason 23 Da Boom.mp4
Server execution failed
I need to solve this problem quickly. Please, give me a clear orientation soon.
Windows Media Player Server Execution Failed.
Hello Addison,
The error you get means that there is some sound driver issues with your Operating system and also that your Windows Media player is not responding and needs to be troubleshooted.
Check if the Media Player is showing up on the task Manager's list when running and follow Vivian Xing's answer highlighted in green.
No body is better in trouble shooting problems regarding Windows media Player other than Microsoft.
Cheers.
Good day to you sir, I see your post and you’re asking about the failed execution of your windows media player. I’m here to give you some tips and to suggest some solution to your problem. Maybe the file you want play has already damage if it is the case maybe you should do some recovery to that or download it again. But if the problem is the player you should do some update to it or install it again. Thank you!
