Luke Kemper
10 points
Posted on - 12/10/2012
Windows mobile device center is a software program that helps to synchronize files between Windows OS and Windows mobile devices. Is there any relationship between windows mobile device center and nokia mobile phones?
Windows mobile device center-nokia relationship.
Selection of Synchronization software program depends on the mobile phone you have.
Windows Mobile Device Center which is developed by Microsoft as a synchronization software program acts as the front-end for the users to integrate data in multiple windows applications. This program has the ability to synchronize the followings:
PIM information with Microsoft Outlook 2003 and later
Photos with Windows Photo Gallery
Videos and Music with Windows Media Player
Favorites with IE
Folders/General files with Windows Explorer
Windows Mobile programs and version updates
There is no connection in between Windows Mobile Device Center and Nokia. In fact Windows Mobile Device Center can be use for Windows Mobile and Nokia can use its Nokia PC Suite or Nokia Ovi Suite.
LyanaHay
The only relationship I found between Nokia mobile phones and windows mobile device center is that new Nokia smart phones are based on windows mobile Os like windows mango and windows 8. By using windows mobile device center you can sync Your Nokia windows phone to your windows OS.
Only thing is you need Nokia's window based mobile phone.
