Windows Movie Maker error message occurred
Windows Movie Maker error message: I desire to identify how I can insert files from a set of connections folder.
I will be happy if you help me to remove this error:
Windows live Movie Maker
Files cant be added directly from a network folder into Movie Maker. Copy the files to your computer, and then tiy again.
OK
Answered By 10 points N/A #174299
Hi Walter W Pilon,
I think you are using Windows 7 and Live Movie Maker where you want to browse network files by use “click to browse” Tab button. When you click on that tab then you are getting this error.
To fix this error you should just follow these steps:
1. Go to your editor of registry
2. Then click on the right button of your mouse at the right pane where an empty space and select the “New”.
3. Set a name of the new value “AllowTheNetworkFiles”
4. After setting a name double click on that and type 1
5. Click on OK
6. And close your editor of registry.
After following this process I think you can do your work efficiently.
Thank you
