Hi experts,
The error messages display those typically encountered while running with DRM protected media. I’ve downloaded a 30 day trial version of DRM protected by Fleetwood Mac track, in WMA format. The error message situated at the upper right displays what I see in Movie Maker 2 when I want to import it. How to solve it? Help me. Thanks.
Windows Movie Maker
The file C:Documents and SettingsPapaJohnLocalSettingsTemporary Internet FilesContent.IE5BEKBZT41Fleetwood_Mac-Sara_0001[1].wma is protected using digital rights management and cannot be imported. |
Windows movie Maker problem error
Hi there ,Â
It seems you are having trouble with Windows Movie maker . I think you are using an unsupported type of file onto the Windows Maker .Â
Just try re-installing (uninstall then re-install )
If re-Installing didn't help means try to contact Microsoft from their Skype website at https://www.microsoft.com/en-us/ .
Don't re-install , First remove Skype from Start -> Control Panel -> Programs and Features  and then uninstall .Â
Then download a fresh copy from www.filehippo.com and then install it.
If still not working meansÂ
1. Try to move onto a better video editing software like ULEAD.Â
Or What do you think ? Or try any other better Video editing softwares that can import the file types of your kind.
Good luck.
