Windows Movie Maker Unspecified error
Hello there Guys,
Guess this should be an easy question for you experts, but since I am new to this kind of error I was not able to figure it out.
I have been using Windows Movie Maker from past few months. Later I stopped using it for some reason and now when I try to play, it tries to open the window for some time and then later comes up error message.
Attached the screen shot for your reference
Windows Movie Maker
Unspecified error
Answered By 0 points N/A #115030
Hello , the best thing you can do regarding these issue is just to restore your computer, from the time that it worked well without problems. To do this click the start button on your screen the move the mouse cursor to all programs then accessories, then system tools.
Or another way is:
Go to the command prompt by clicking start – programs-accessories then Command Prompt a DOS window will pop-up, then type:
Set then hit the enter key the result will be:
TEMP=C:/DOCUME~1UserNameLOCALS~1Temp
After the equal sign is a path into the temporary files. Change the directory to
CD C:DOCUME~1UserNameLOCALS~1 then enter
If it doesn’t exist just create using the MD Temp then Enter reset the attributed by executing these commands
Attrib-r+a-s-h temp then enter
And That’s it…It really works for me.
