“Windows NT error number 109 occurred”
Why does “Windows NT error number 109 occurred” always happen? I constantly found this error in my log files. How to get rid of it? Please help. Thanks!
Hi
This Error “Windows NT error number 109" is basically caused or generated when a query launched in your browser has timed out and/or if the user click on the stop or refresh buttons before the query is completed and page is completely loaded.
For example if you are connecting to a server that is slow or overloaded, and your page is taking too long time to be loaded, then you may click the refresh button and maybe you will repeat this operation several times, the result is that for each click you have made you will get an Error 109 that is recorded in you log files.
Thanks
