Windows operating system error messages
I am clueless as to why I have the error message while I am performing some operations on WINDOWS. I get different types of errors such as 0×80070570 and 0×80070006. Here is how it looks like on my computer environment.
How do I get over this error messages? Why has this errors occurred?
Error:
The handle is invalid.
Answered By 0 points N/A #150606
Dear Nelson,
I can see you have an error that is related to system. It could happen because of windows file corruption, system file missing or any viral infection. If there is missing which is recoverable then you may try System Recovery Tools . It will help you to install your computer system onto an earlier date. Here is the process :
1. Go to START MENU
2. Then Select All Programs, slide down to Accessories
3. Go to SYSTEM TOOLS >> System Restore.
4. Select “Restore my computer to an earlier time “
5. Select an earlier date from the calendar view.
6.  Click Next to finalize the procedure.
I hope this will help you solving your problem.
