Windows Phone Emulator error PC may be lose network connectivity
I have this message with my Windows Phone. It appeared for the first time after I have reinstalled my Windows 7, it worked just fine before the reinstall. I don’t know what I should do, click Yes or No. Can anyone help me with this? If is possible please tell me some advices.
Thank you!
Do you want to configure the emulator to connect to the Internet?
Your PC may lose its network connectivity while the changes are applied. This may affect any network operations in progress.
Yes No
