I use a Windows phone. Yes, a Windows phone. It used to work fine but now it has started behaving a little weird. It has started throwing error code 800704cf at me. I do not know how to fix this issue and I need help. It is possible?
Windows Phone Error 800704cf Fix Found
Even though the number of Windows phone users are relatively small around the globe, a majority of Windows phone users have reported this problem. They are either unable to connect to outlook, or they can only access the internet through internet explorer.
As a result, some solutions to the problem have also come up. If you are unable to sync your accounts automatically, try manual sync from settings->accounts->microsoft account-> synchronize. It is observed that resetting the date and time settings of the device also solve the problem in many cases. If none of these work for you, do a soft reset of your device. Please make sure that you backup all your data before doing this as it will result in a complete loss of data.
