I have a Nokia Lumia 535 Windows Phone bought recently and still in perfect condition. I have saved some documents (pdf, word, excel, powerpoint etc.) from my computer. The problem is that I can’t access any of these office docs (word, excel, PowerPoint) via the Nokia Lumia save for the pdf ones. I have confirmed that these documents show on my SD card when I access them via the computer. I have also backed up a few copies via OneDrive and realized that these show up too. However, I can’t rely on this method since I have to set my internet on something which is pretty costly. Downloading a file manager app from the store won’t solve my trouble still. What could be done to prevent visibility of office documents via Nokia Lumia Windows phone? Is there a way I can solve this? Login into office via the windows phone also gives an error therefore rendering my efforts futile. Please help.
Windows Phone Won’t Show Any MS Office Doc on my SD Card
If you badly needed to open the documents on your computer to your phone, the easiest solution is to copy the files to a microSD card then insert that microSD card to your phone and that’s it. Just open the files on your phone from the microSD card. The Microsoft Lumia 535 is available in two versions: single SIM and dual SIM.
The Microsoft Lumia 535 Dual SIM is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled to the public on November 2014 and released on December 2014 measuring 140.2 x 72.4 x 8.8 millimeters and weighing 146 grams. It uses two micro-SIM cards and has IPS LCD capacitive touchscreen display with 16M colors at 540 x 960 pixels screen resolution.
It supports multi-touch protected with Corning Gorilla Glass 3. It ships with Microsoft Windows Phone 8.1 powered by Qualcomm Snapdragon 200 chipset, 1.2 GHz Quad-Core Cortex-A7 processor, and Adreno 302 GPU. It supports microSD expandable up to 256 GB. It runs on 1 GB RAM with 8 GB internal storage. The primary camera supports 5 megapixels with f/2.4 and 28mm featuring autofocus, LED flash, 1/4″ sensor size, and geo-tagging.
It supports 480p video recording at 30 fps. The secondary camera supports 5 megapixels. It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic; Wi-Fi 802.11 b/g/n with DLNA and hotspot support; Bluetooth 4.0 with A2DP, LE, and aptX support; GPS with A-GPS and GLONASS support; FM radio; and microUSB 2.0. It has built-in proximity and accelerometer sensors.
The pre-installed web browser supports HTML5. Java is not supported. It runs on removable BL-L4A Li-Ion 1905 mAh battery with standby time up to 336 hours and talk time up to 11 hours on 2G and 13 hours on 3G. It is available in gray, blue, orange, green, white, and black colors.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
