Windows Program Usage Gives Out 0xc80003fa Error
Give points on the 0xc80003fa error? what is the cause of the error code and explain the methods to overcome this error message?
The error code displayed as ‘ERROR_CAN_NOT_DEL_LOCAL_WINS’ or as value 0xFA1 which means “The local Wins cannot be deleted.” 0xc80003fa error is a Windows update error code that usually occurs on the Windows system when the user runs a Windows program on the Windows operating system.
Several main causes of the error are incorrect records, damage to Windows system files, corrupted system files, incomplete installation, unacceptable application deletion, installation deletion, virus or spyware, ad attack, incorrect BIOS settings, old drivers, etc.
This error occurs if you cannot access the %SystemRoot%\SoftwareDistribution folder during Windows Update.
The step to fix the error code is shown below:
Step 1: Check the system files with the following commands:
sfc /scannow
dism /online /cleanup-image/Restorehealth
Step 2: Check the WU settings in the computer.
Step 3: Clear the WU cache with following commands:
net stop Wuauserv
cd %systemroot%\SoftwareDistribution ren Download Download.old
net start wuauserv
Step 4: Restart the computer and check for the error again.
