Windows requirements for Adobe CS6 Production Premium
I want to buy an Adobe CS 6 Production Premium or Master Collection. Is that compatible with my Windows 7 32-bit running on my computer?
Good Day,
Upon reading your question i think the answer to your question is no.. because some of the Adobe Software / Programs is requiring a 64 bit Operating System. they started implementing that requirements in some of CS 5 products so i am quite sure that it will mostly implemented in Adobe CS6 Collection.
In order to install "Adobe CS6 Production Premium" your machine should have these minimum requirements:
Processor: Intel Core 2 Duo or AMD Phenom.
RAM: 4GB or above.
Graphic Card: 512MB 16-bit color.
As for Windows 7 32-bit you'll face a problem with "Adobe Premiere" and "SpeedGrade", they all support 64-bit only.
Regards..
Your current system is not compatible with Adobe CS6 Production Premium. To be able to run it, you need to have an Intel Core 2 Duo or AMD Phenom II processor with 64-bit support.
The same also with Adobe CS6 Master Collection, where you need to have at least an Intel Pentium 4 or AMD Athlon 64 processor with 64-bit support.
The minimum system requirements for Adobe Photoshop CS 6 Production Premium installation is provided below:
