Windows restarts and checks the System Failure Box automatically
Hello!
I am having a problem with my computer. I restarted my computer as per instruction of Control Panel. After restarting It was fixed for a while. But, after some time it has restarted automatically. I also unchecked the System Failure Box but unfortunately when I went back to the options the unchecked box checked automatically. I don’t know what’s going on with my computer. I am wondering if you can help me out. Thank you.
Answered By 5 points N/A #106106
Hi user
Were you logged as an administrator to change the settings in System Failure, otherwise your settings won't be changed.
You need to find the source of the problem first. It could be a corruption of the operating system files or one of your hardware is malfunctioning. To get more information go to the file whose directory is shown in the under dumb directory in System Failure, these information can used by a technician to determine the cause of the trouble. Boot in safe mode to do all this. If you want you can do system restore to overcome the problem. Use a restore point that was created before you met with this problem. All your installation will be lost though.
