Hello everybody!
Please answer me about error reporting on windows.It is very boring for me. I don't get this error message.
Microsoft Internet Explorer
Microsoft Internet Explorer has encountered a problem and needs to close. We are sorry for the inconvenien
If you were in the middle of something, the information you were working on might be lost.
Restart Microsoft Internet Explorer
Please tell Microsoft about this problem.
We have created an error report that you can send to help us improve Microsoft Internet Explorer. We will treat this report as confidential and anonymous.
To see what data this error report contains, click here.
Windows ‘Send Error Report’ dialogue box.
It is appear sometimes and when I click on the cancel button then my dialup connection is terminated.
SomeProgram
SomeProgram has encountered a problem and needs to close. We are sorry for the inconvenience.
If you were in the middle of something. The information you were working on might be lost.
We have created an error report that you can send to help us improve SomeProgram. We will treat this report as confidential and anonymous.
What data does this error report contain?
Why should I report to Microsoft?
Why coming this error report? What is error? I want to get rid from this type of encountered report in the future.
Windows send error message reporting
Hello, here is the solution. Follow the steps that un-install existing MS Internet Explorer IE and instead install IE 9.0
Click the ‘Start’ and choose ‘Control Panel’.
Click twice ‘Add or Remove Programs’. A programs list is shown.
Find out the version of IE.
Choose ‘Change or Remove’.
If the service package is installed recently, IE will be invisible on the list. If you use Windows XP, on the left-hand area of ‘Add or Remove Programs’, you can select ‘ AddRemove Windows Components’
The wizard will be opened and Windows component can be removed or added. So un-click Internet Explorer and choose ‘Next’ to un-install IE.
Restart.
Install the IE again.
Install IE 9.0 from here. Finish.
Restart.
Hope this could help.
Hi there,
This ‘Send Error Report’ is caused by corrupted Internet Explorer software.
The best remedy for this is to uninstall and re-install your Internet Explorer browser.
An error message will pop-up everytime you browse a webpage or open the browser itself. Once open, the Internet Explorer is trying to load but because of software conflict, this window will pop-up.
I have here steps to perform before you uninstall/reinstall the Internet Explorer, follow the steps below;
Optimized your browser
Go to Tools, Internet Options
Under browsing history, click on the Delete button
Delete all history, cookies, files, data, form, password
Click Ok, close and re-open the browser.
Try opening your Internet Explorer but it won't work, try the steps below
Delete the Dial-up connection
To go Tools, Internet Options
Click on Connections tab and remove dial-up under Dial-up and Virtual Network Settings
Reset your Browser into default
Open your browser, Go to Tools, Internet Options
Click on Advanced tab and click on Reset
You may also click on Restore Advanced Settings
These steps should refresh your browser back to normal but if everything failed, my first suggestion is the best remedy. Uninstall and re-install it.
