Windows Server 2003 black screen problem
I booted up and tried to logon to a Windows Server 2003 Standard client connected to one of our local servers when suddenly the screen went black as in the color black with the logo of 2003 Server at the top of the black screen. It seemed that I can type commands since there was a cursor blinking, but I didn't do so because I might destroy something. I tried to boot up in safe mode, but the same thing happened. How shall I resolve this?
Thanks in advance.
See black screen as displayed on the PC:
Windows Server 2003 Standard Edition Copyright @ 1985-2003 Microsoft Corporation
Microsoft*
Windows Server 2003
Standard Edition
Copyright @ 1985-2003 Microsoft Corporation Microsoft
(Windows black screen error)
Best Answer by brian23
Answered By 0 points N/A #88120
Hi Alfred,
Start your computer in one of the ways, start windows in safe mode, you may use the last known good configuration.
To start windows in the last known good configuration, On startup press F8 key. Move the arrow keys and select the last known good configuration and press enter. If this doesn't work then start your computer in safe mode.
To start in safe mode, Press F8 on startup and move the to select safe mode using the arrow keys on the keyboard. Press enter.
After the computer has started, use the event viewer to identify the cause of the problem.
Click on start menu-control panel-administrative tools and click on event viewer. Follow the steps promptly to identify the cause of the start up error.
