ikrampmc
Posted on - 10/03/2011
Generic Host Process for Win32 Services encountered a problem and needs to close.
My Server with Microsoft Windows Server 2003 encounters an error every time when I restart it that is Generic Host Process for win32 Services. When I send the report to Microsoft they give no reply or solution of the said problem.
It happens only when I logged in Windows.
Please view image attached.
David88
Windows Server 2003 Generic Host Process Error
This problem only occurs in Windows XP service pack 2. Microsoft has released an update to minimize this problem. You can download this update from this link on Microsoft. Download it, Install it and reboot your computer. Hope you won’t see this type of error again.
Regards!
Maybe there is a problem with the operating system’s installation or there is a service that failed permanently due to corrupted data. Try checking your computer for any possible errors.
Use a disk utility application when checking the system. For a much thorough diagnostics on the system, use a disk utility application like Norton Utilities, PC Tools Performance Toolkit, or Norton SystemWorks.
It is possible that an error in the file system permanently disables a component in the system that’s why you keep seeing the error message every time you start the computer.
If diagnosing the system didn’t help, I think you need to format the hard drive and install the operating system again.
