kurt andrew
10 points
Posted on - 05/30/2012
Windows Server 2003 Standard Edition, I am trying to install Kav 6 for Windows Server on it. The built-in Administrator account I have logged on and started the installation.
No domain belongs to the server. Error 1923: the installer shows the following error. Service Kaspersky Anti-virus could not be installed.
Kaspersky Anti-Virus 6.0 for Windows Servers Error 1923.Service Kaspersky Anti-Virus 6.0 (AVP) could not be installed. Verify that you have sufficient privileges to install system services.
Windows Server 2003 Standard Edition Kay 6 installation error
I don’t see any system incompatibility issue here since you are using Windows Server 2003 Standard Edition provided your system is using the right Service Pack that is required by the antivirus.
If this is the first time you encounter this problem when installing Kaspersky antivirus, try restarting the computer then try it again.
Be sure you are logged in as the administrator before launching the installer or run the installer as administrator if it’s available in the option.
If this doesn’t work, let’s review first the system specifications of Kaspersky Anti-Virus for Windows Servers 6.0.4.x. This version of Kaspersky supports Windows Server 2000 Advanced Server Service Pack 4 R1,
Windows Server 2003 32-bit Standard/Enterprise Service Pack 2, Windows Server 2003 64-bit Standard/Enterprise Service Pack 2, and Windows Small Business Server 2003 Service Pack 2 R2.
It also requires installing Microsoft Windows Installer 2.0 or higher. Since your installation failed, check first if you are running the right version of the operating system or the right Service Pack
If you have already installed Microsoft Windows Installer before starting the installation for the antivirus.
If you still haven’t, install Microsoft Windows Installer first before starting the installation for Kaspersky.
To know more about the antivirus and other specifications of the program, please visit Kaspersky Anti-Virus for Windows Servers 6.0.4.x.
