Windows Server and Active Directory
I have a server running SBS 2003. In the last few days the hard drive crashed/died and had to take it to data recovery company. I had a replacement drive installed and the recovery company had luck recovering the image, and we installed it into the new server hard drive.
As far as am concerned everything is ok as except one kind of a crucial thing in active drive users and computers. I can no longer create objects.
I have tried creating computers and accounts but both fail and I get the following error message:
Active Directory
Windows cannot create the object testuser because:
The directory service encountered an unknown failure. OK
The server is working fine, but the error makes it very uncomfortable and may crucial if not rectified. I have researched on the Internet, posted in several forums, but still not been able to obtain helpful information to correct this error.
Does anyone know what I can try to get this system back operating properly?
Thank you.
