harie
Posted on - 11/02/2011
Dear friends,
I need to join one of the networking companies. The company is running on Windows based. I need to know how to configure Windows servers to that company. How to Admin that servers.
How to troubleshoot that servers. I also need to know how to configure Active directory. I need step by step explanation. If anybody has good materials, please upload to me.
Jackman
Windows servers 2003 and 2008
Before you start this kind of configuration you will need to configure the server's IP address. At the command prompt type [netsh interface ipv4 show interface] make note of the number of corresponding networks that your computer has and the network adapter that you will use to form your IP configuration.
At the command prompt type [netsh interface ipv4 set address name=" " source=static address mask ga] then at the next prompt type [netsh interface ipv4 add dnsserver name=" " address= index=1] You may repeat this step for your Active directory server.
To administrate you need to set up a password at the prompt type [net user administrator] when prompted to add a password add it and a user account then press enter. It prompts you again repeat the password and press enter.
You will choose whether you want to activate it fully or remotely. I hope this will be of help to you.
