Windows service stopping any application running in my pc.
Hello fellows,
Windows service stopping any application running in my pc. My Windows 7 starter Os is having a weekly update and it causes my other application to stop. I don’t know the main reason why is this happening? Can you give me some idea how to get rid of these?
Thank you.
Martha Nelson.
Answered By 0 points N/A #172713
By default windows download and install important updates to your PC to keep it secure. Now here are some tips to solve your problems.
1.   If you are working in production environment and your PC is connected to your work network, please double check with your system admin for any restrictions on software update policy.
2.   Try to disable the windows update from the control panel.
3.   Check for a newer version of your software would be more compatible with your operating system.
4.   Consider installing a fresh copy of your operating system.
Trienity Maria
