Windows services fail to run when the computer starts
 I need your help for solving this error which arose when I upgraded to windows 2003 from windows 2000. First, some windows services fail to run when the computer is starting and second, sometimes I get a message bearing the words “The page file is too small” or “You do not have a page file”. I don’t understand why this is happening so please help.
Answered By 20 points N/A #116194
Hello Brice,
This could be an error due to the operating system or the specific program that you are executing at that, for instance ms office word or any other program that you might be working on.
It seems like the upgrade may have caused some incompatibility issues with some programs and applications that you are using and hence the error that you are getting. Therefore I will advice that instead of the upgrade, remove it and do a clean installation of windows 2003 so as to clear all the windows 2000 files that may be causing the problems, and also ensure that you use applications that are compatible to windows 2003.
_
Regards
Mahesh Babu
