Windows Show Error Code 0x3e7 After Installation
I have recently installed a new version of Windows on my computer. But after installation, the computer doesn’t start, and an error code 0x3e7 is flashed on the screen. How can I repair my computer?
Answered By 0 points N/A #290505
First, run your computer in safe mode. When you can log in to your PC, follow the steps below.
1. Open the Start Menu.
2. Go to Control Panel
3. Click on ‘System and Maintenance.’
4. Select ‘System’ and then go to ‘Device Manager.’
5. You will be asked for User Access Control
6. Click on ‘Allow.’
7. In the ‘Device Manager’ window drop down all the CD/DVD ROM drives.
8. Uninstall all the CD/DVD ROM devices from your computer
9. Reboot your computer
