I need Windows software to create ambient noise. I know about Nosili and it generates sound but its not what am looking for. I would like to know of similar websites or software that generate the sound offline. Any suggestions are welcome. Also include the features for those software.
Windows software that creates ambient noise for offline use
Hi Bennie Easter,
You could check Drone FX. In this software, you can play along with soundscapes in auto mode or generate an ambient music without using built-in keyboards. Although this software is not free, you can try it on your browser. You can also visit this documentation page, to know more about Drone FX. I hope this tip will help you.
Martine Paul
Hello Bennie S Easter,
I would recommend trying Resonance. It's free and it comes preloaded with presets like rain, birds singing, train and many more.
There is a useful feature which allows you to combine multiple channels and create your own mixes.
Each channel has its own volume control so you can control all of them separately.
And though it does not shine with its user interface, Resonance gets the job done pretty well.
