Windows System 32 Logilda Dll Could Not Be Found
Hey Anusha, this kind of error usually arises after an update into your computer, it’s not like its not good to upgrade, but sometimes users encounter to it because of software conflicts and environmental issues. It occurs when you update your system into Windows 10 or Windows 8.1. It occurs due to the incompatible version of Logitech software, to fix this error go to the Task Manager, go to startup tab you need to find Logilda. Right-click on logilda and Disable it. Now download the ‘ Logitech Download Assistant’ we need to delete the Entry so that this error won’t occur again and it doesn’t disturb you.
For this, you need to press Win+R and search fir REGEDIT you need to back up the registry go to HKEY_LOCAL_MACHINE\Software\Microsoft \ windows\current version\ Run. Now you need to search for Logitech download Assistant and delete the entry. You have to Reboot the system for the changes. If this doesn’t work and you register the whole entry Download the CCleaner. Open it go-to tools in the start-up. Select Logitech down Assistant from the list and delete it. This process is simpler and quicker
