While trying to download and install updates on my home computer, Windows started throwing windows update error 800706ba at me. I am not very good with computers. I don’t know how to get past this error. Can you help?
Windows Update Error 800706ba Fix
This issue is common when users try to download the latest Windows Updates and feature manually. In the case of some missing system files or corrupt files, it is common for the system to throw this error.
To get past this, you need to run a full system scan to ensure that you are not infected with some virus or malware. After you do that, boot up your computer in safe mode with networking and then try to download and install your updates. Sometimes, the third-party antivirus installed on your computer sometimes interferes with this process that also causes this error.
