Windows Update Error 8024402F on Windows 7 Home Premium 64bit
The Windows Update Error 8024402F is due to a connection interruption on your PC and the Windows Update servers. There is a automatic fix from Microsoft website below:
Microsoft Fix it: Windows Update Error 8024402F
Another way is to disable your antivirus software temporarily and then run the update. Or you can manually check on your internet connection if there are any issues with it. To configure your internet connection to get an IP address automatically, follow the steps below:
1. Click Start and type NCPA.CPL and press enter.
2. Right-click on the network connection and then click on Properties. If you are asked for the administrator password, type it to confirm.
3. Highlight TCP/IPv6 and then click on Properties.
4. Tick the Obtain an IP address automatically and Obtain DNS server address automatically check boxes and click OK.
5. Reboot your computer.
The error code 8024402f occurs when there is an interruption between the computer and the Windows update server.
You may try the following steps to have this matter resolve:
You may also want to run the Windows Update troubleshooter. It is available through this link, and it can help you fix some issues with Windows update automatically.
Just follow the steps that are provided on the said site to have the issue resolve.
Notifications
