I tried to run Windows update but I get this error instead. It says windows could not search for new updates.
Any ideas how to resolve this?
Error:
Windows could not search for new updates Error code 88023212.
Most recent check for updates 4/17/2010 at 1:43 PM
Updates were installed 4/17/2010 at 2:17 PM
View update history
You received update For Windows and other products from Microsoft Update
Thank you!
Windows update error code c355
Hello christine
The best way to fix the error c355 is to download updates in safe mood.
You just restart your computer, when your computer is in booting process hit the F8 key.
Now you will see many options select safe mode. From there you are able to download updates.
The second way is to download registry cleaner.
This is a large database which stores vital information of your computer.
You can resolve you error c355 by using registry cleaner application.
Hopefully it works.
Thanks
Make sure that you can connect to the Internet correctly when attempting to fix Window update error code c335 when Windows asks whether you want to apply Windows Updates automatically the first time you got your computer, it is better that you can set it to automatically.
If you agreed to turn Automatic Windows Updates on then you most likely have all the latest updates from Microsoft.
You may encounter error code “0x80073712” when running Windows Update. This problem can happen if the CBS or the Component-Based Servicing manifest is corrupt. In Microsoft Windows 7, one way of fixing it is to run the System File Checker utility or the SFC tool. Click “Start”, “All Programs”, “Accessories” then right-click “Command Prompt” and select “Run as administrator”. This should open an elevated command prompt.
In the command prompt window, type without quotes “sfc /scannow” then hit Enter. Insert your Windows setup DVD on your optical drive when you are prompted and then continue. When it is finished, run Windows Update again and install the update. See if this works. If this doesn’t fix it, use the System Update Readiness Tool. Go to Fix Windows Update Errors using DISM.
Download the version applicable to your operating system. Once downloaded, run the tool then wait until it is complete. Once it is finished, run Windows Update again and see if it works.
