Windows Update Generates 8050800c Error
Discuss the 8050800c error? Explain the steps to resolve the error code and the cause of this error message?
8050800c error occurs when the user tries to look for the Windows Defender update. The error message gives a description “Windows update has encountered an unknown error if try to install it.”
A simple solution to resolve the error code is to install the update manually by following the described steps:
Step 1: Download the Windows Defender update file manually.
Step 2: Start the system in safe mode.
Step 3: Run the downloaded exe in safe mode and reboot.
Step 4: It’s fixed.
Another solution to fix the error is to make sure that the user doesn’t running a third-party antivirus, and the user can also clean the registry to resolve the error code.
