Windows Update Shows 80200056 Error
Show your views on the 80200056 error? What is the cause of the error code, and explain the methods to overcome this error message?
The 80200056 error is caused by a failed Windows update or by interference from a third-party. The error code gives the description “Update error 80200056 applying update operation 3337 of 69398 (prnmm…).” The method to fix the error code is as follows:
Method 1: Check the driver updates.
Download and install the latest driver.
Method 2: Reset or refresh the computer.
Method 3: Check the computer for malware.
Step 1: Download and install Malwarebytes 3.0.
Step 2: Open the application and click on the Scan Now button to start the scanning of the computer.
Step 3: Click on the Quarantine Selected button once the scan is finished.
Step 4: Click on the Yes button to restart the computer.
