Windows update stand alone installer
Hi folks,
I am running Windows 7 on a 2GB RAM, 3.0 processor 160GB hard disk hp Compaq 610. I have downloaded Windows Server trial version from the server from the Internet and through tedious installation procedures only to get error message, then I get redirected to a hot fix site that I have downloaded many times only to get an error message:
Windows Update Standalone Installer
The update does not apply to your system
This install update is proposed by MSDN to use WinHlp32.EXE in Vista and Windows Server 2008 to launch and so I do not understand why it does not work.  I’m not very savvy on computers, so the easiest explanation you can give  will be appreciate greatly. Thank you.
Best Answer by spacegirl
Answered By 5 points N/A #80515
Follow the steps given below:
  • Open this. LINK: https://support.microsoft.com/en-us
  • Click RUN NOW “Diagnose and repair Windows File and Folder Problems automatically”. Save it and run it.
  • Let it check for errors and restart your computer. After it is done, restart your computer.
  • Click RUN NOW “Automatically diagnose and fix common problems with Windows Update”. Save it and run it.
  • Visit https://support.microsoft.com/en-us/help/10164/fix-windows-update-errors
  • If you are using Windows 7 x64 bit, download Windows6.1-KB917607-x64.msu
  • If you are using Windows 7 x32 bit, download Windows6.1-KB917607-x86.msu
  • Once you have selected the file you need to download, install it.
  • Restart your computer.
