Camella
20 points
Posted on - 12/10/2011
I have created Virtual Hard Disk with Microsoft Disk2VHD toll.
On it I have done some backup files, but only on it I have back up files.
When I want to use this Virtual back up error message appears.
Please help, I need to solve this problem it its possible.
Thank you in advance.
Camella
Windows Virtual PC
Cannot attach the virtual hard disk to the virtual machine. Check the values provided and try again.
OK
Windows Virtual PC Cannot attach the virtual hard disk
Good day camella
Here I provided you a solution to your queries.
Your problem means you have a Virtual Hard Disk file larger than 127.5GB. Which Virtual PC does not support.
In other words, we’ve captured a 160GB hard disk, and Virtual PC won’t let us use it.
But we can fix it, it’s a two step process
First we use DiskPart, and then we use VHD Resizer.
1.DiskPart
DISKPART> select vdisk file=c:usersdaledesktopworktest.vhd
DiskPart successfully selected the virtual disk file.
DISKPART> attach vdisk
100 percent completed
DiskPart successfully attached the virtual disk file.
DISKPART> list volume
Volume ### Ltr Label       Fs    Type       Size    Status    Info
Volume 0Â Â Â Â EÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â DVD-ROMÂ Â Â Â Â Â Â Â 0 BÂ No Media
Volume 1                     NTFS  Partition   100 MB Healthy   System
Volume 2    D               NTFS  Partition   199 GB Healthy
Volume 3    C               NTFS  Partition   265 GB Healthy   Boot
Volume 4    F               NTFS  Partition   149 GB Healthy
DISKPART> select volume 4
Volume 4 is the selected volume.
* Volume 4    F               NTFS  Partition   149 GB Healthy
DISKPART> shrink querymax
The maximum number of reclaimable bytes is:Â 106 GB (108636 MB)
DISKPART> shrink desired=40960 (Note: desired is the amount we want to prune of the image)
DiskPart successfully shrunk the volume by:Â Â 40 GB
* Volume 4    F               NTFS  Partition   109 GB Healthy
DISKPART> detach vdisk
DiskPart successfully detached the virtual disk file.
DISKPART> exit
What we now have is a VHD file still sized at 149GB, but with a 109GB partition in it. What we need to do next is resize the VHD to 109GB.
2. VHDResizer.
Use VHDResizer to resize your newly shrunk VHD file, in this example WorkTest.VHD
(and yes, you picked a New Size larger than 109GB, you went for 120GB instead).
And finally…
Success! It boots!
iamraymone
