Jem Mandap
50 points
Posted on - 02/22/2013
Hello People,
We are trying to create, modify and deploy a windows Vista WTM image through our network in our training labs. When I try to activate the OS it is getting this error message.
The following information was found for this error:
Code:
0x8007232A
Description:
DNS server failure.
Thanks in advance for the help.
Windows Vista Activation Error: Code 0x8007232b
Dear Jem Mandap,
Hope you are well.
To fix it, try to enter the MAK key again but after disabling any firewall and internet security program.
If this is not effective, try to make updates for Vista before activation by way of the Update Wizard in OS and download important updates to fix this problem.
Hope this was helpful.
Best regards,
Don Muench
