Windows Vista Error Code 646: Some updates were not installed
Windows vista update error. What are the steps to fix Windows update errors?
In an instance 1 or more update would be having problems, Is it the ISP or the update itself that has problems?
The connection of the internet though is fine!
Windows Update
Failed: 1 update
Error(s) found:
Code 646 Windows Update encountered an unknown error.
Get help with this error
Most recent check for updates Today at 9:02 AM
Updates were installed Today at 10:39 AM
View update history
You received update For Windows and other products from Microsoft Update
Find out more about from Microsoft Update. Click here for details.
Best Answer by Edmund Joseph
Answered By 0 points N/A #149410
You have to fix it through the registry fixing software provided by Microsoft.
If you want to get it, visit the link here:
After downloading, install and run it. It will check and fix the errors.
If the auto fix cannot solve your problem, then you have to fix it yourself.
The video lesson can be found:
Answered By 5 points N/A #149411
Hi there user:
Quit all open software and follow these steps.
Reset the Windows Update component and then install the update. Open the Windows Command Prompt, click Start and then Run. Type ‘cmd’ and then hit Enter.
Then type ‘net stop bits’ and ‘net stop wuauserv’ and then Enter to stop the BITS and Windows Update service. Type ‘Del “%ALLUSERSPROFILE%Application DataMicrosoftNetworkDownloaderqmgr*.dat”’ to delete qmgr.dat files. Now type ‘cd / d %windir%system42‘ and then Enter.
Now this is abit long process, just press Enter after each command prompt.
‘regsvr32.exe atl.dll’ Enter
‘regsvr32.exe urlmon.dll’ Enter
‘regsvr32.exe mshtml.dll’ Enter
‘regsvr32.exe shdocvw.dll’ Enter
‘regsvr32.exe browseui.dll’ Enter
‘regsvr32.exe jscript.dll’ Enter
‘regsvr32.exe vbscript.dll’ Enter
‘regsvr32.exe scrrun.dll’ Enter
‘regsvr32.exe msxml.dll’ Enter
‘regsvr32.exe msxml3.dll’ Enter
‘regsvr32.exe msxml6.dll’ Enter
‘regsvr32.exe actxprxy.dll’ Enter
‘regsvr32.exe softpub.dll’ Enter
‘regsvr32.exe wintrust.dll’ Enter
‘regsvr32.exe dssenh.dll’ Enter
‘regsvr32.exe rsaenh.dll’ Enter
‘regsvr32.exe gpkcsp.dll’ Enter
‘regsvr32.exe sccbase.dll’ Enter
‘regsvr32.exe slbcsp.dll’ Enter
‘regsvr32.exe cryptdlg.dll’ Enter
‘regsvr32.exe oleaut32.dll’ Enter
‘regsvr32.exe ole32.dll’ Enter
‘regsvr32.exe shell32.dll’ Enter
‘regsvr32.exe initpki.dll’ Enter
‘regsvr32.exe wuapi.dll’ Enter
‘regsvr32.exe wuaueng.dll’ Enter
‘regsvr32.exe wuaueng1.dll’ Enter
‘regsvr32.exe wucltui.dll’ Enter
‘regsvr32.exe wups.dll’ Enter
‘regsvr32.exe wups2.dll’ Enter
‘regsvr32.exe wuweb.dll’ Enter
‘regsvr32.exe qmgr.dll’ Enter
‘regsvr32.exe qmgrprxy.dll’ Enter
‘regsvr32.exe wucltux.dll’ Enter
‘regsvr32.exe muweb.dll’ Enter
‘regsvr32.exe wuwebv.dll’ Enter
Type ‘netsh reset winsock’ and then Enter to reset winsock
Restart BIT and Windows update service by typing ‘net start bits’ and ‘net start wuauserv.’
And then restart your computer.
Thanks for posting here at techyv.com
Best regards,
Answered By 0 points N/A #149412
You recommend you to disable your firewall. If you’re using McAfee Personal Firewall Plus, Norton Internet Security or another
Firewall vendor.
If you’re using the built-in Vista Firewall, keep reading.
  •  Open the Control Panel and select Security.
  •  Select Turn Windows Firewall on or off.
  •  Select Off (not recommended), click Apply and then OK.
  •  Back at the Windows Update screen, click the Try again button.
The download and installation should start and this time properly install.
If a restart is required, make sure to re-enable your Firewall once your PC restarts.
