Windows Vista error with Nero
I am using Windows Vista Operating System.
Yesterday, my system experienced some problem which showed Nero error code 2755. I further used the set up program, but the error persisted.
I was wondering about how to fix this issue.
Do you have any idea?
Please let me know.
Thank you.
Best Answer by Jeffrey Atala
Answered By 0 points N/A #149618
To solve this problem, try to follow the instruction step by step:
1. Switch on the pc and then sign on as an admin.
2. Click the Start button then click Programs, Accessories, System Tools, and then click System Restore.
3. From the next screen, select “Restore my machine to a prior date” and then press Next.
4. Choose the freshest restore point in the “click a restoration point” listing, then click on Next.
5. Then click Next within the verification screen.
6. Reboot the computer system when the rescue is finished.
Hopefully your problem will be solved.
Enjoy.
Answered By 0 points N/A #149619
Hai,
Step 1:
First, we'll start with PC Cleaner Pro. This program specializes in Windows repair. It fixes, Internet Explorer errors, ActiveX errors, JavaScript and scripting errors, C++ errors, EXE/ DLL/ OCX/ INF/ VXD errors, slow sluggish behavior and tons more errors. Not to mention, fine tune your PC for maximum performance.
Here's how to use it.
Download PC_Cleaner_Pro from internet.
  1. Double click on the PC_Cleaner_Pro.exe icon on your desktop.
  2. By default it will install to C:Program FilesPC Cleaners.
  3. Click on Install and follow the on screen instructions.
  4. It will create a PC Cleaners icon on the desktop.
  5. Once installed, launch PC Cleaner; it will automatically start a scan.
  6. When it's finished, click on Fix All. (Register if required.)
Step 2:
The Reimage program specializes in Windows repair. It scans and diagnoses, then repairs, your damaged PC and not only fixes your Windows operating system, but also reverses the damage already done with its full database of replacement files.
Download ReimageRepair from internet and run it.
Hope this helps.
